BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
On the recent new to me 2018 RTL which had 8240 miles on the clock when I bought it, I found that it had a vibration at highway speed, so I moved the my Centramatic balancers from the front of my other Spyder to the new one. Out of the highway I could see the left front Kenda not running true and still causing a vibration in the trike. The rim appeared to be running true, so the issue was the tire. So I put the PPA wheels and Vredestein Quatrac SL on it and it VERY smooth on the road now. The Champagne one got it's original wheels with Federal Formoza tires re-installed.
AT 1,249 miles the Elka shocks and 2013 RS blade style wheels were installed(moving the OEM Kendas to the new wheels, and I have the OEM wheels without tires) with 2 oz counteract balance beads in each wheel/tire. And this Spyder got a new set of Kenda tires because of issues at 1,383 miles, as I have all the service records on it. So it appears that Kenda tires have been an issue with this one right off the dealers showroom floor. I probably should call the seller and tell him the vibrations have been solved.
Thanks .... I've said this and so has Peter ..... Kenda tires that can NOT be balanced is not UNUSUAL and the ratio of defective tires produced by Kenda is quite large ..... JMHO ....Mike :thumbup:
