Popping the shocks out is not really all that tough of a job (I managed to do it with almost NO bloodshed! :shocked
First; you'll need some 15mm wrenches or sockets. Getting to the bottom shock mount bolts is easy; I used a 1/2"drive socket on one side, and an open end wrench on the other.
The top is a bit "tight" I used a 3/8" drive up there, and a bit snorter, more compact open-end wrench.
Get the nuts off the ends of the bolts first...
Then; jack the bike up so that the wheels are JUST off the ground...
Supporting the wheel with your knees,feet, or a friend's helping hands; get the bolt out of the lower mount. I used a rubber mallet for a bit of persuasion...
The top one should be nice and easy to pull out now...
Your OEM shock is now rattling around in there like the metal ball in a pinball machine... wiggle it around until you can figure out the best way to get it out of there... It'll come out; it just takes getting your tongue just right... nojoke
The springs on the OEMs are at the top. When you mount the Elkas; the springs will be at the bottom.. :lecturef_smilie: this is VERY important!
Get them stuffed up in where the shocks should be ( A bit of a wrestling match...), and get the top bolt through...
Now... get the lower mount and lower end of the shock lined up (This is when having a friend to help is really useful!), and slip the bott through
Get your nuts in order...
tighten them up; re-check them! and you're ready for the road! :thumbup:
