clueless
figure I would post this separate as a thread as I am sure others have broke theirs ...
this is the plastic cover over the DIN plugs in the trunk for the IPOD plug also used for the front and rear intercom DIN Plugs.
we broke the rear one. the hinge on these things disintegrates!
The part is listed with NO PICTURE in the 2011 accessory catalog ... http://www.brp.com/FlipBooks/Catalog...anAmSpyder.pdf
bottom page 37 and the item part for the kit = 219400315
its a cap assembly and the metal screw ring that holds it on... once you unscrew the existing one you will see how it mounts. I am sure they probably have a tool to tighten the metal ring easier. I used small needle nose pliers
