Different Block Off Plates, RT
rick_w
I was at the Solon, Ohio Car Show this week and saw a Spyder RT with some interesting Upper and Lower Block off Plates installed.
I took a picture, it was a little different. I don't think I have seen Exhaust Tips used like this before.
They had fabricated plates with exhaust tips. It did look a little different from a distance.
attachment.php
I think this to be a marketing opportunity if any venders are listening. I like em!
That's pretty gaudy in my opinion. Why not just go with spyderpops solution which looks so much better?
If they were adjustable they might be really useful different climates
Sent from my HTCONE using Tapatalk
:agree: If you could twist the body a bit to direct the airflow for different temperature conditions... :2thumbs:
This actually looks as if it's got a lot of marketability! :clap:
That would be worth something if they were adjustable. Never know maybe someone will have an idea.
I would have to get used to the looks of them personally. From a distance if you didn't know what they were, it looked like exhaust coming out from the side. I do believe that was the idea, they probably had a car at the show also. I didn't see anyone around the Spyder to talk to.
I seen an spoke with him about them an I do think they can move if you wanted them to. They are 3 inch exhaust header mounts on a block off plate he drilled it out to fit. They look an work well he said. He even added 1 on the other side just to make it look right an confuse non spyder ppl. I started to get my parts the other day.
