Stridersr7
So on my 09 SE5. I took the drain bolt out of where you put the oil in. Then took off both filters. Replaced both filters. Put the drain bolt back in and filled it up. Cranked it. Went thru neutral and first back and forth a few times. Was there another drain bolt? If so then if I took it out now I guess all the new oil I put in would spill out and is it something I need to worry about this time? Just noticed when I got the hiflo filters from baja Ron that there were 2 copper washers is why I ask.
