Diameter of the f3 Bars?
bikerbillone
Well-known member
As in the title, what's the diameter of the f3 bars? Getting the 'short reach' bars for my 2020 RTL so that's a vital piece of information. I assume they are the same as OEM on the RTL, so to be safe, just asking. Thanks.
The bars are the same diameter (F3 and 2020 RT) I had them on my 2020 RTL but did not like how far they came back
so I took them off and sold them. But good luck with yours and hope you like them.
Toby
I found short reach handlebars on Ebay for around $140.00. (just the bars and new hardware)
They are easy to install and will come back about 2+ inches.
Make sure you remove the caps (5mm Allen screws) first on each side. Once you remove them the grips will slide out of the handlebars.
Then loosen the 4 bolts holding the handlebars to the bike ( MAKE SURE YOU LOOSEN THE CLIPS HOLDING THE ELECTRICAL BEFORE REMOVING THE BAR and transfer those clips to the new bars.
The bar I purchased came with all new hardware!
Rotax
Thank you one and all. Yeah Toby, I hope I like them, no fun spending the big bucks only to find out it doesn't work as planned.
I have mentioned it in other threads. I have the short reach bars installed on mine. Makes the F3 fit ME like a glove. I am 5', 5". Its now like I am sitting IN my Vulcan cruiser.
Excellent Arkansas, that is comforting, I'm 5"6" since I shrunk a bit. :>)
I have the #2 position brake rod also. Just added a wider brake pedal. The combo is great for me.
I am also inseam challenged. 26/27.
Had to lower the rear on my Vulcan to touch the floor with both feet.
Arkansas, I see that Lamonster has the same pedal as SpyderPops, so was your install just remove a couple bolts or more complicated. Lamonster has that fits through 2019, SpyderPops says through 2020, but they look the very same.
