Jetfixer
Well-known member
A word of warning. Since the 2024 model year, Spyders, both RT's and F3's, have had a major change to the handlebars. I'm not talking about the switches and their new locations. The handlebars now are tapered at the ends and are NOT interchangeable with earlier model year handlebars. Also, you will NOT be able to use items such as Lidloxs on these bars. The ends of the bars are threaded for the stock bar-end weights. Also, if you DO want to swap out handlebars from stock to the optional Can Am handlebars, (such as Short Reach), be aware that the left grip is mounted to the handlebar by 2 torx screws, that are not obvious. You must pull back the rubber grip to find the screws. Do not try to force this grip off the handlebar, it has a very small two conductor wire for the grip heat that is easily broken.
