AJ, What are the steps that you use to reset your spyder?My new module is on the way.
I can still get it to reset - BUT I just know that on a long ride 100s of miles from a Dealership it will give up the "Ghost".
No hassle from Dealership or BRP. Just need to wait forever being on the Left Side of the USA.
When the fix is made will post the Part #, but expect it to be what has been posted previously here.
AJ
TNpapa- I got mine started with 4 or 5 quick turn on and offs without letting the bike reboot per this thread.AJ, What are the steps that you use to reset your spyder?
Can your dealership put a rush on the "New Module" so you are not spyderless?
Looking forward to seeing your post of the Part #.
Deanna
Good Luck! Did you pay for reprogramming the keys?Going to pick up the bike in a few. Module was not replaced. Having them print out the brp case number in case I have problems again.
:agree: That is what my dealership said to do, and I posted on this thread. DeannaTNpapa- I got mine started with 4 or 5 quick turn on and offs without letting the bike reboot per this thread.
Deanna
No charge Deanna, just without my ride from Monday until today. Had them print out the brp case number.Good Luck! Did you pay for reprogramming the keys?
Reprogramming the keys is under warranty, the second time that I got the D.E.S.S. my dealership changed the module, and reprogrammed the keys, and I did have to pay, because it is under warranty.
Deanna
AJ, I had the module replaced twice with in a month last year. ( July first time, Aug. second time).Deanna
Not Spyderless, still use every day since once it's cleared it will not reoccur for months.
To reset, if not interference from outside source, I've had to remove the positive lead from the battery and touch it to ground.
As for "Rush" . . . the word is not in the French vocabulary
AJ
The next time you get the bad key error on your F3, would you post a picture on this thread?I wonder if given the difference between the RT display and the F3 display my bad key error isn't the same problem as the d.e.s.s error.
If you get the D.E.S.S Error again( which I hope you don't) please post on this thread.No charge Deanna, just without my ride from Monday until today. Had them print out the brp case number.
The module is under warranty, take a picture and show it to your dealership, then your dealership can not say it did not happen. Also, on this tread their is some excellent info for you take to your dealership. Keep us posted on what happens. Deanna
Thanks for the picture! Good LuckHere is a picture of when it happened last time.
Keep us posted. Deanna
The D.E.S.S. module is under warranty". Do you have any warranty left on your spyder?The dealer just called and BRP is going to replace the entire D.E.S.S module this time. I guess last time they just replaced the antenna.
So you did not try " Turning the ignition on/off immediately, do not let the system shut down for 4 to 5 cycles"? That is what my dealership recommended to me when I had the D.E.S.S. Key code show up.
I think "Rush" should be in the French Vocabulary, then you are not spyderless.
Deanna
Why did it take 8 days from Quebec to get you?The quick on/off never worked for me.
New DESS module and ignition (part numbers as you previously described) have arrived at Dealership. Took @ 8 days from Quebec. Installation scheduled for Friday Morning.
I assume (never a good idea - lol) that since I am receiving a New Ignition also, that I will get a new set of keys, nes pas
AJ
With your "New Ignition" your dealership should reprogram your keys( the originals) to your "New Ignition". When I had my 2nd D.E.S.S. module replaced, and my first switch replaced my dealership reprogrammed my keys and gave me a new trailer lock.
Let me know if you get a "New set of keys" since you are getting a new Ignition.
Keep us posted!
Deanna
