dltang
Very Handy Member
Sorry, I was busy at work and missed your question about why you do not remove a helmet at a motorcycle accident. I did say only if they needed an airway but I didn't get to answer the rest of your question. Here it is.
If breathing is taking place normally, leave the helmet on!
It is very dangerous to remove someone's helmet if they have some type of cervical/back injury. The only time it should be removed is if the airway is blocked and cannot be cleared with the helmet on or if it is necessary to perform CPR.
If the airway is blocked or there's no respiratory action, then you should remove the helmet. The method recommended by the American College of Orthopedic Surgeons requires two people.
Open visor, remove glasses and unbuckle the chin strap. One person should be to the side of the head of the victim and the other person should be directly behind the head of the victim, stabilizing the head to avoid excess movement.
The person on the side puts one hand under the victim's head supporting at the base of the skull. They put their other hand on the jaw bone/chin . They will be supporting the head, so it is important to get a good solid grip. Keep some tension in the arms so that if the person pulling the helmet slips the victim's head won't drop.
The person sitting behind the head will then slowly pull the helmet directly back and off of the head. Watch out for catching the nose on the chin-guard on full-face helmets, as well as ears and earrings. It's normal to rotate the helmet forward as you pull it off, but not this time. Pull straight back so that the head and neck are not rotated.
After the helmet is off, put a leather jacket or something under the head of the victim! If the person supporting their head lets go, their head will drop a good 4 inches or so. This would not be good. If possible, it would be best to have a third person ready with something to place under the victim's head once the helmet is off.
After the helmet is off, the person behind the head should again hold the victim's head to promote cervical immobilization.
I hope this information helps with anyone that is ever on the scene of a motorcycle accident.
