This Spring, I rode the S2S for about 500 miles or so, then it got cold, so I parked it. Later I moved it into my garage, put it in neutral and moved it around by hand, shut it off.
Yesterday, I tried to start it up, and it starts to make a noise like a solenoid to a starter with a bad battery.
I took out the battery, took it to O'reillys, they said it was ok.
I did the voltage test with it off, key on, then hitting start. All good.
I currently have 4 codes in the display: P2301, P2307, P2304, U0100. The latter was the first code I found, then more I messed with it, the more coded I got.
It seems like something happens in the transmission when you first turn on the key. Not sure. I noticed the N light flickers when whatever solenoid is being triggered.
It will start, but immediately shuts down after starting.
I made an appt with the local dealer, but rather not go through the work of trailering it to them, so thought I'd post this and see if there is anyone else seen something like this and if there is an easier solution.
It is under warranty, so don't want to void that.
I have searched the forum, but not finding much, maybe I'm just not finding the right combination of words to match something.
Tom
Tom
