OK, sorry y'all, but we're taking a little break from the saga of "Teddy's Tail" for a day or two, as I'm a little frazzled, frustrated and confused at the current time.
I've been working on a sun/canopy for the Tedster and thought I had made good progress til a new realization hit me yesterday. I originally planned on a tri-pod style mounting system using 3 Ram-Mounts attached to the rear area over Teddy of the Spyder and also the plastic wind-shield (from a mo-ped I think) that Teddy was given by Kathy and Joe a few weeks ago. I was originally going to put one Ram-Ball on the back of the Utopia BackRest and then mount another Ram-Ball to the Top-Left & another to the Top-Right of the rear trunk-lid. Upon talking this over with Coz & a couple of other local Spyder Ryders, we realized this would work, but then I wouldn't be able to open or have access to anything in the rear-trunk, anytime the canopy was in position. I don't know about any other ryders, but when we're on long road-trips, we usually use all of the trunk space on Teds Red Sled, so this wasn't a viable option.
So I kept thinking, and instead of mounting the two back legs of the tri-pod mount to the rear trunk lid, I thought about installing them on the rear passenger elbow pads that are never used and are right next to the rear trunk lid, so almost the same position. It was agreed that doing it this way, it would be a viable option. Since the elbow pads are made of foam, I figured from the amount of vibration and wind turbulence, that they would probably be torn up in a matter of weeks, and that wouldn't be good. So, I started taking Teds Red Sled apart, peice by peice, bolt by bolt, to see what I could see and how things were put together back there in the passenger area. I actually took off the "Elbow-pads" and decided to mount the Ram-Balls on the hard, flat plastic peice that the "Elbow-Pads" were previously mounted to and this not only worked, but it didn't look all that bad either. My remaining concern is that without the "Elbow-Pads" being installed, there's about a 3 inch triangle shaped area that is now left open to the elements, and I'm not liking that thought, but haven't quite figured out how to remedy that issue just yet, but I'm thinking it IS managable.
So I went with this direction, and at first, all was progressing well. Got all three Ram-Balls mounted, got the 12 inch PVC Ram extensions cut down to the size where I thought it looked best and provided the most amount of noon-day shade for the little guy. Rock On!!! We're doing good! Since the shield was only lightly tinted and we're using it to provide shade, I went ahead and added a non-transparent "Diamond-Plate" auto film, that I had been saving for over a year now, to the top-side of the shield. I knew going in that this was my first time applying an auto-wrap of any type, and with the shape and design of the shield, I knew it wasn't going to be perfect, and I was ok with this fact, as I knew this entire thing was a learning experience for me.
So, we got the wrap installed and it didn't look too bad, tho I did have some very noticable creases at the front of the shield, but oh well, lets hook it all up and see if it works. Sure enough, hook-up all three legs and make sure their mounts are tight, and off we went for a test ryde. We did about 30 miles of all kinds of roads and highways and all speeds from slow to fast, and with Teddy needing a little time to get accustomed to his new digs, I was thinking all was well.................. That is til we stopped to get gas.
TBC....................... work, work, work.............................
