Prior to my 600 mile service, which was done at 873 miles, the only time I felt any vibrations on my floorboards was around 5,000 RPM. Once I got to 5500 it was gone and everything was smooth as silk up to 8500. The first thing I noticed after the 600 mile service was increased vibration in the 4500 - 5500 range. Since that time, the vibrations have gotten worse, to the point that they are there between 4000 - 8500 RPM. There does seem to be a second contributor in the 4500 - 5500 range (belt harmonics?). Additionally, since the 600 mile service, when the :f_spider: is going up hill or accelerating, the vibrations are noticeable in the handlebars and grips as well.
Thinking that the dealer may have set the belt tension to the pre-2013 value of 450 N rather than the 1050 N value for the 2013s, I purchased and installed a Baker Built belt stabilizer. It didn't help in the least. I also noticed that there is an annoying buzzing sound that wasn't there before and which increases in frequency as the engine RPMs increase.
I bought a Krikit II gauge and checked the belt tension according to the manual. I repeatedly got readings of 160-170 lbs. I realize the Krikit is not designed for our belts, but can anyone tell me value you should be getting with a Krikit on properly tensioned 2013 belts?
I'm hoping Scotty or Lamont or one of the other more knowledgeable folks can give me an idea of what's going on. I will be calling Pit Bull on Tuesday and setting up an appointment to have this looked at.
