BertRemington
CW -- I bought this assortment https://www.amazon.com/Hilitchi-180-Pcs-Metric-Bonded-Assortment/dp/B07CKVYWD4/
The rubber insert is 2.5 - to 2.6mm thick and the metal rim is 2mm thick. I used a digital torque wrench with the same settings for metal washers although 15Nm would probably be adequate.
Turns out that assortment was handy. I've been using the washers as spacers, etc.
