Bored at 2am, accurately measured with a digital vernier caliper, and the large cap O ring ID checked for roundness and accuracy on applicable tooling.
As I mentioned earlier, none of the oem O rings are typical black nitrile material. As can be seen, they use a soft silicone type and high temp Viton type.
Small drain plug gasket is copper, large drain is gasket is aluminum.
Forgot too how many drain plugs I accumulated when dimensionally checking them on account of failures. Have two sets of Dimple Drain Plugs, One set of Gold Drain Plugs, and a set of oem drain plugs. Ironically, others have stated aftermarket drain plugs fail, yet no issues here and, when I was doing the comparison, I was handed a failed oem drain plug.
What does it mean...likely the torque spec is for a new engine with clean dry threads, and second, if you must torque your drain plug, adjust accordingly for a wet torque AND, be certain you have a good or excellent accurate torque wrench that you are properly using. This means correct range markings and set correctly.
All the best with your quest to save a few dollars, I get it, but certainly hope you get the correct type and material O rings. Never fun finding melted, swollen O rings or worse, split housings from excessive expanding force.
