Customer Acc outlets
Rotax
Can anyone tell me the following.
On a 2016 F3-S.....Re Customer Accessory outlets.
I know where they are, I just wanted to know when they have power?
Only when Engine running?
When Ignition in Acc position?
Or power always?
Thanks
Rotax
I can't tell you about the F3, but my RT has an outlet in the trunk.
By default, it only has power when the key is ON, but by moving a fuse, you can make it live all the time.
Your F3 might have a similar feature.
All but one are hot only with the engine running. There is one on the left side by the front of the seat that is hot when the key is on. It is meant for your GPS to hook up to. Lamonster has included a longer wire harness on his Fog lights to hook up to it and still be able to power your GPS. it would also be a good place to hook up your glow lighting that you want hot to show off your lights. They did it so you can listen to music on the sound system without having the engine running. If you want a plug that is always hot, hook it directly to your battery. The plug I have for charging my phone is always hot.
