Custom Dynamics Double/Triple Play Frustration
Flamewinger
I'm really struggling to figure out how to install the Double Play into my ST L. The connectors that should be in behind the speedo are not there. The only connectors I can find are at the mirrors. The CD wire harness won't work.
I had problems installing the Cool Magic Billet lights. The wire harness needs to be modified and the bolts that come out of the light housing need to be a little shorter.
Any ideas on how to plug the Double Play into the ST??
I have not ordered lights for the ST...cause when I've called Custom D they tell me they have no lights for the ST
ST Lights
If you go to their website they have a number of lights for the ST. I have ordered the 3rd brake light and LED rear turn signals from them.
I learned that the triple play for the rear end works for the ST but the double-play only works for the RS and I'm still waiting to see if something becomes available for the front of the ST.
Their cool Magic billet lights do work but you do have to modify the harness to get it to fit right. And you have to be careful when you're mounting the lights since the bolt runs into the metal underneath and pinches the wires.
