Crack in the tupperware
Farmbanker
I was cleaning up the spyder for what I hope is its short winter nap and I noticed a crack in the tupperware right behind where the passenger's right heel would be. spydercrack.jpg. I suspect an inadvertent kick by the passenger and I am wondering what I should do. It isn't noticeable enough to have to replace the part, and I am sure BRP sells these really cheap.:roflblack: I am thinking about using a fiberglass repair kit on the backside and thicken it up a bit for more strength. Anyone else have this problem? Should I do this on the other side too to prevent it being damaged in the future? Or should I be thinking of doing something else? Your thoughts and suggestions as always are welcome.
I would ask an auto repair shop how to repair the crack. If a repair does not fix the crack, then a replacement panel might be in order.
Are you sure it is a crack, and not a scratch? If it is a crack, it is the first I have heard of.
I doubt that a fibergalss repair would work, and the wrong resin could melt the plastic. I'd rough the piece (and remove the paint or insulation on the back), then use a universal plastic mender, with some reinforcement. As another alternative, I might try Gorilla Glue and some reinforcement...like a piece of heavy cloth or canvas, or another piece of plastic. JMHO...no guarantees!
I've repaired many plastic panels on ATVs with a solder gun from the back side of the crack.
But that will only stop the crack from getting larger,
A new panel would be in order if you want it look perfect.
Defintely a crack, but good suggestions. I too was very surprised to see this crack. Wasn't expecting that the plastic could be so thin.....
If the Spyder is still under warranty, I'd report it to your dealer. It is an unusual problem. I might report it even if it is out of warranty.
If all else fails, ie no warrentees, I would drill a small hole at the very end of the crack. This will release the pressure and stop it from getting bigger. Then use superglue gel to secure the crack. The superglue will melt the plastic a bit so use very little, just enough to cover the crack. Then on E Bay Show Chrome sells a Carbon fiber self adhesive "kick Protector" for that area. It comes in two parts for each side and it will cover the messy repair work and no one will be the wiser. If you are really OCD (obsessive compulsive disorder) about it, just buy a new part.
Yak repair tool
Go to a local Kayak dealer or look on-line for a kayak repair tool. Similar to soldering iron, but with different size flat tips. Try rubbing along the back and see if its melts it closed. I works wonders on Yaks, but they do not have the nice polished smooth surface.. Just a thought...
:agree: I was going to suggest the very same course of action... :thumbup:
Great suggestions! I would not have thought of them. I will definitely give that a try. Thank you so much!
Mine cracked top to bottom in late July. I noticed it when I was in Iowa and heading toward S. D. It went another 4K miles with no issues, tape, etc., before being changed out in November. It was covered under warranty.image.jpg
Sorry to hear about the crack in the tupperware. I would lean towards the dealer fix under warranty solution for starters. As posted earlier, this is not a problem that we have heard a lot about. With your past problems, I don't think a warranty fix or replacement is out of line.
Please keep us posted.
If you go with the superglue and the crack is visible, you can dust (the wet glue) it with ordinary baking soda to act as a filler and gradually fill it in. Of course you'd have to sand and paint afterwards.
