bluestratos
I suffer a lot from heat, something to do with being a diabetic. I purchased a cooling vest which has tubing stitched into it and then plugs into a an ice filled cooler. The one that came with it was less than ideal so i bought a new 30 quart hard cooler with a plastic liner. I transferred the pump and plumbing into this which makes for the perfect set up. I have a spare power outlet built into the aftermarket seat heater so I pick up the power off of that.
The system works by putting a bag of ice into it followed by a quart of ice. Depending on how long it is used it will last about 3-5 hours on a bag of ice. I am now looking for a drain valve so I can quickly empty the water out when I am done or need to add another bag of ice.
I can see that running it all the time would be too cold on some days and reaching around back to pull/reinsert the power plug would be a pain so I built a timer that allows me to cycle the pump on an off: 3 minutes on, 2 minutes off. I also installed a mini three way toggle switch that allows me to go to full on, timer on and off. I will have to fine tune the timer cycles but it is easy to set. I am looking forward to mother nature turning up the heat now
