Coolant
MrBlonde
Was thinking of changing the coolant and was wondering if I should use the BRP coolant or the Motul that I use to use in my Raptor or is there a better one?also how often should the coolant be drained off and changed out?
Depends..!
if you are using motul in your other vehicles why not. As long as it is aluminum safe. There are many out there, ice, and water wetter are good as well. Here in hotter climates We use 75% water 25% premix coolant. Change it every year but depends on your use and ryding conditions...:thumbup:
Cheers pal :) even in summer here in Scotland it never gets too hot but these Spyders seem to run fairly hot is this normal? Mine sits at 5bars in and around town but drops to 4 when up to speed??
Spyders do run rather hot , luckily not too much of a problem in the UK , like you say Mr. B.
Like the #2 response said- Every 2yrs is the recommended change- BRP coolant is pricey- any local auto parts can get a gallon- Prestone green -aluminum safe-& is way cheaper.
You can use Water Wetter. It's a Red Line product. I use 4 oz. in my 2011 RS-S SE5 and temp. went down one bar when added to Prestone 50/50 mix .
Mike
Is this the type of Prestone brand?
attachment.php
