jcthorne
Well-known member
You cannot control BT volume to your headsets using the volume buttons. That only adjusts speaker volume. For BT volume you adjust it using the BT headset knob. If you think about it this makes sense because 2 people may have different volume desires.
Bob
Mine does, always has. Volume controls and mute work fine from the handle bar. When I swapped out the radio between mine and my wifes RT looking for the noise problem, it still worked. Something different in the 13?
There is a setting to disable the speakers, I have that set to disable the speakers when using the radio on the headset, otherwise there is an echo. So only the helmets have output via bluetooth, could that have something to do with it?
