Here's someones opinion that I thought made sense....[TABLE="class: w100p"]
[TR]
[TD="class: brdr1_b brdr1_t bgrnd19 pad mgn_t, colspan: 2"]
Rapid Robert
Enthusiast | Posts: 328 | Joined: 01/06
Posted: 01/19/06
11:10 PM
[/TD]
[/TR]
[TR]
[TD="class: pad, colspan: 2"] First off, if you drained out more oil than what is supposed to be in it including the oil filter then it was overfilled. Over filling is very bad thing to do, crankshaft will agitate oil causing air to be whipped in to oil which will cause less than adequite lubrication through out the engine. Never run engine below the add mark or over the full mark on the dip stick
Yes you can change oil on a cold engine. By cold meaning cool enough to touch the engine. Rememeber that the purpose of the oil filter is to trap dirt, not the oil pan. Oil pan serves only as a collection place for the oil to be pumped through the engine, it is not a dirt trap. If you have a lot of "silt" type dirt in the pan you are not changing the oil often enough and if its a high mileage engine you will have actually have extremly fine metal silt in it also. Thats why a magnetic drain plug in the oil pan is a good idea. Never change oil with out changing the filter, never! Asuming that you change your oil (non- synthetic) within 4 months or 4,000 miles which ever comes first, you should never have an oil related problem with your engine.Best non-synthetic oil is Penn.base oil such as Quaker state, Pennzoil, Wolfs Head, Amalie, Kendal and other marked as Pa. base crude oil. They have the highest level of parrafin base content which is an excellant lubricant.
Warm engine will cause the oil to flow slighty better out of pan but you trade off the extra time you will needed to get the oil that is on top of the engine to drain down to the pan and out of the engine.
Either way is OK because the little bit that stays behind , about 1/4 to 1/3 quart is not enough to be concerned with if you change oil and filter at the intervals listed abouve
[/TD]
[/TR]
[/TABLE]
