I will admit that it makes it easier to deal with the Throttlemeister when you are used to throttle tension, but that has little to do with the strength of the return spring, but rather a throttle tensioning device that hinders the spring action. You may like the feeling of the throttle snapping back when you let go, but it is not a good safety practice. To do so loosens your grip on the throttle, making sudden avoidance maneuvers riskier and slower. In addition, if you are not used to turning off the throttle, you will delay in responding to a broken throttle cable or spring, also creating a risk. It is like getting used to turning off the bike with the kill switch. If it is second nature, you will not delay if you need it someday. Think about this, at 60 mph you will travel 88 feet farther if you delay for one second. How many obstacles could that 88 feet contain?
