Code p0707
troyboy
Today my wife and I went for ride and about 30 miles into the ride when I shifted into 4th gear my check engine light came on along with the flashing neutral light and a flashing reverse light.
Then when I shifted into 5th gear the two flashing lights went out but the check engine light stayed on. I did the sequence to get the code and it came up with p0707. I looked on my iPad Spyder app and that code is not on there. The nearest I can tell is it is the gear box position sensor. Any help would be very much appreciated. Thanks in advance Troyboy.
Sounds like..!!
your right. The closest is PO709 which is gear position sensor. You could check the wiring, fueses and relays but here lately we are seeing problems with the paddle shifter. Don't know which you have. Hope it's a glitch and removing the key and walking away will cure this ill.:thumbup:
I'm sorry I should have said it is a 08 gs sm5, you are right that is the closest code on the app and the symptoms leads to the gear box position sensor.
Interesting..!!
Have seen several going out lately...two on 08's...maybe they have a short life span..:roflblack:
