CnC Machines Dash Mount
george123
I just installed the dash mount on my 2016 RT Limited. What's the best way to run the wires to the battery in the frunk? Is it safe to run them thru the windshield mount holes?
Yep, I ran mine through the right hand (throttle) side and over to the battery side after taking both the windshield and the front dash cover loose, easy peasy. Run my windshield up and down, many, many times since with no problems.
Thanks for the quick answers. I've got jury duty in the morning, so I'm hoping we get finished early enough that I can finish it up tomorrow afternoon/evening. Then move on to the next project.
Just walk in and say "hang him"....they'll send ya home early.:lecturef_smilie:
I took off the cover around the instrument panel, and I can get the wire down by the upper rt w/s mount. When I try to fish it down further toward the battery, i hit a dead end. is there another opening to fish it thru?
use zip ties
I ran the wires for the GPS ( Garmin 660lm) through the center windshield slot but used very small zip ties in a small drilled hole to keep the wire from chaffing against anything.
Chaffed electrical wires cause--------------- Kaos
