Insy
Hello from the Rainbow Nation.
The patient : 2009 SE5, K&N filter,02 Modifier, non cat split pipes.
When changing from 1st into 2nd at around 5000 RPM the change is immediate and direct. However when changing from 1st into 2nd at anything higher , I.E. when cranking it, the clutch slips. Same applies through all the gears. I can't say whether the engine temp has anything to do with it as I never give it horns when the engine isn't good and warmed up.
I have read a number of threads on the forum which make mention of oil pressure being a possible culprit and would appreciate feedback / comment from fellow :spyder2: owners who may have experienced / solved this problem.
Wait to hear and you all ride safe.
