lil rabbit
Looking for some help and information on a problem I am experiencing on my Spyder RS 2010. Just had a major tune up done by my dealer and had no issues going home. But that night when going home the check transmission light came on and after I got home I checked the oil level which was fine. Removed the key and then restarted and light was gone. So the next day coming home from work I was in 3rd gear and slowed down for a intersection and applied some throttle after I passed the intersection and the bike only revved up and would not go but the bike indicated it was in 3rd gear. So I pulled off the road and turned off engine and removed the key to reset computer... I had to this a couple of times before the bike would actually shift again. :banghead::banghead: Made it home with no other problems, however a couple of days later coming off the freeway, I down shifted to 4th gear and the same issue came up again. Did the key removal and finally was able to shift and no other problems... So any help or suggestions will be greatly appreciated. I am taking the Spyder back to dealer but was wondering what could be the cause.
