A
arntufun
Guest
I have a slight leak where the plunger pushes in when you pull the clutch lever in. It's not alot but enough to see a speck appear on my yellow top cover every now and then. I know brake fluid is not good for the paint and I need to get this fixed.
Here is a couple of questions for people that would know about the workings of a clutch. Thank for your help in advance. I might have more questions depending on the answers I get from you.
1. Is this part a wear item not covered under warranty ?
2. Do I need to replace the whole fluid reservoir or can that plunger seal be rebuilt ?
3. Is that plunger something that can be tightened to stop the seepage ?
