Mine was different than the others I read. Theirs was forward shifting and mine was down shifting. But I did react in time to get a code. It is P0826. Shift up/down switch detection problem. Is this a problem that can be corrected by me or does it have to go to the shop? And how bad is it?
For those that don't know what I be talking about mine happens when I try to manually downshift. The engine sign comes up and it reads check transmission. Also the paddle does not work well, will not shift up or down. But if I keep playing with it it will go into gear and sign will go off. With mine its mostly down shifting with paddle and slowing down. Hope this helps anyone that this happens to.
So is there anything I can do myself to correct it??? Thanks for any help!
