Check Transmission Warning - My story
On my way to the dealer today to get the Windshield bracket replaced (Another story see the thread )
WARNING FOR ALL RT OWNERS * You may want to check
About 4 miles from home and the Check Transmission? Warning came up along with the light in the display
Spyder RT-S SE5 Still running and I was in 4th Gear
Looking for a safe place to pull over and tried to change gear it would not go up or down
Found a side road and stopped the Spyder and it showed 1st gear
Turned it off back on, Foot on brake it started went into Neutral but would not change up or even reverse
Also noticed all my lights were out – Yesterday I replace my number Plate bulb with an LED which was Can-Bus safe – This one had heat shrink at the back This had blown a fuse I believed I still had the Spyder connected to a battery tender and this was the cause
Once the fuse was replaced and the battery tender removed all was tested OK
So I decided to replace the Fuse for the lights and they worked but blew the 15amp fuse
Now I also believed I had an Electrical and Low oil problem
Had no Oil with me so decided to call out the UK AA (Automobile Association) Breakdown Service
Whilst waiting for them to arrive I decided to remove the LED Number Plate bulb
Once it was removed -Key in Spyder in N Started and was able to shift into 1[SUP]st[/SUP] gear, Quick check up the road and all gears were working and the Check Transmission Light did not come on
Cancelled the AA and made my way to the dealer with no further problems
Have since replaced the Number Plate bulb with a standard one
Questions
How can a blow 15amp fuse for the lights bring up the Check Transmission warning and also not allow me to change gear
Can I replace the Rear number plate bulb with a none Can-Bus type LED Bulb
Just posted this just in case someone has a similar problem
