Check engine light
Paco441
My new 2011 RT-S has a check engine light problem and only runs on one cylinder. The morons at my dealer are having trouble figuring it out. Anyone else having the problem?
Only 500 miles on it.:helpsmilie:
I have a friend with RS SM5 from Venice using the WestCoast Powersports dealer in Clearwater...:popcorn:
Same thing happened to me. One cylinder firing said they going to re wire whole system. They called BRP and were told to replace ECU. No problems after that.
I had the same problem last Sept. It was a bad spark plug wire.
The ECU is the engine control unit. Your problem could be there, a bad plug wire, bad coil, a bad spark plug, or a combination of these. Probably fouled the O2 sensor, giving the engine light. There may not be a diagnostic code if the coil is firing but the spark is shorting out to the head. My 2010 RTS needed to have the ECU, coil, wires, and spark plugs all replaced to cure it. BRP tech should be able to help your dealer. Some techs do not understand that the computer cannot tell them everything. Really not happy to hear that this type of problem is showing up on the 2011s, too.
