Check Engine Light Coming on 2012 RT Limited 450 miles.
Gary1951
My check engine light is coming on, then going off after a few minutes.
It started doing this when my gas was low. After gassing up, I checked the oil and coolant level and they are ok.
Any suggestions are appreciated.
Thanks,
Gary
:agree: Just make sure that you do this while you're getting the warning light...
Good Luck, and please let us know which codes pop up! :thumbup:
Default Codes
Ok, next time it happens I will ck as instructed and report results.
Thanks,
Gary
Meaning of Fault Code Engine Warning A2530?
Bob,
It happened again. I finally figured out that you need to press all 3 buttons at the same time.... The default code was P2530... What do you think?
Gary
Sounds like a loose connection to me. When I bought my 07 MX-Z X-RS the high beam wire rubbed on the frame and shorted out. Hopefully it works out to be something simple like that for you.
