Check Engine light and dealer says not to worry?
Iwrk911
I have a 2013 ST, basic model. The other day my display changed from white to orange, then started flashing "check engine". I am a new Can Am owner with very little mechanical background. Had bike towed to local dealer. After 3 days received call it was ready. They told me it was a sensor that measures the air temp. And not to worry. Rode 38 miles home with no problem. Get on next day, less than a block it starts flashing again. First in the trip meter area, then in the middle blocking the speed. The little check engine lite is on also. Called dealer and service person said ride a bit longer, maybe earlier in the day when cooler and see if it happens again. Texas gets hot, right now it is around 102 degrees, the thermometer in dash says 123. I don't want to damage the motor, but at a loss. The bike only has 1145 miles on it. Any help will be greatly received.
Your dealer is BS you pull up the code on your display and we can tell you what it might be.
Press mode, turn signal cancel, set all at the same time
Your display should only change from white to orange when you ride at night or in changing light. I had the check engine light come on also. The reason for it was that I had used a couple of tanks of 91 Octane Gas as I was unable to get 95, this then activated the Knock Sensor which brought up the check engine light.
Also a couple of New ST's here had their check engine light come on, and it was found that the Knock Sensor Plug was not securely plugged in.
I hope this helps
Temp.
Intake air temperature too high air temperature Intake fault no service action I still think it is BS here in Fl we ride with temp in 95 s
That is what they told me it was, kinda annoying watching the display flash and change. Thanks to the reply by both of you. Will ride it and see what happens.:pray:
Air temp sensor
If memory serves me it will throw codes and put the spyder in limp mode @ 122* and above. This high temp can be reached in a few ways. One being heat soak...say you have been riding the spyder in high temps and shut it off for a while....but not long enough to cool down...just long enough for heat transfer to happen. A condition that worsens if it's shut down with the sun beating down on it too. Another could be low anti freeze, and yet another could be a stuck thermostat, or, the radiator fan is not coming on.
As has been said. Your dealer is not being your friend. If they DO NOT want to stand behind the product. FIRE THEM and go elsewhere. If you do. Notify BRP that you have....and why. There's contact info in your OM and on the home page of this site.
Best of luck. :doorag:
Sitting
The bike sat all day, yes in direct sunlight. The temp. Was around 100 degrees today. I started it and with in 1 block it flashed, rode it a few miles, let it sit for around 45 minutes, rode back to house. Never had a problem with bike, just the constant display changing. The temp. Gauge on dash of Spyder said it was 125 degrees
Curious..!!
how long and how far are you ryding..?? If its 100* out and you ryde on asphalt the temp coming off of it is around 170*. If you do not move the air out of the engine compartment with some ryding or the fan you will get over 122* at the sensor causing this code. Take the long road home..the road less traveled..maybe tree lined or by a lake or gulf to cool her down. :thumbup:
I had the same problem when we were coming through the Mojave. When the display guage reads more that 122 degrees you are going to get the P0127. It goes away once you get air circulating. Mine did not go into limp mode with this issue, and it doesn't take long for the temp to go down with air flow.
local
This was just across town to a resturant. This afternoon I will get it out on the road and pick up speed to see if the display stops. Again thanks to everyone that replied, reply's...
I remember getting this code quite often on my 2013 RT. Have all of the updates been done to your Spyder? Did they do the computer update? I haven't heard any of the other 2013 ST owners mention if they are still getting these codes after having the new panels and updates done.
I know someone who just purchased a 2013 ST from a Texas dealer and they had not done any of the updates/recalls on the bike. So please contact your dealer and have them tell you exactly what updates have been done on yours.
My 2010 RT has done this several times on really hot days. On mine it always happened after having been parked for a time on hot pavement. Never took more than a riding a couple of blocks to clear the limp mode and the code. My dealer talked to BRP about changing the software to increase the temperature it took to cause the code but, to my knowledge, they never changed it. It's not hard to exceed 120 - 130 degrees when parked on hot pavement.
Cotton
Not Saying mine was the same!
I seem to have had the same problem with mine when it was new! don't remember the code but it turned out to be a bad batch of vacuum lines and a faulty O2 sensor! and they changed out the plugs! If I remember it was running to lean on the front bank! Hope this helps!
Safe Ryding Ya'all
kubie:doorag:
Totally :agree: Nothing wrong with the spyder. This is Normal & all do it. Dealer did nothing wrong either.
This is included in the Do's and Do Not's...
Clarification on the P0127 and P0217 code messages: (From Steve with BRP customer care) Some have experienced the P0127 and/or P0217 codes on their Spyders so we'd like to provide additional information on what they mean. The following is the link to this thread started by Steve, from BRP Customer Care:
http://www.spyderlovers.com/forums/s...P0217-messages
'13 RT
Did you ever resolve my issue? That is the problem I am having currently with my 13 RT.
Are you getting the P0127 errors? You would likely see this happen if the temperature reading says 120 or more and if you are going slow. If you get back up to speed it should go away. That was my experience on my 2013 RT
