CB/auxilary speaker help
viperryder
I have a 2014 RTS SE6 with a dealer installed CB. I added a GPS last year, but have not been able to hear the GPS thru the radio. I have printed out the suggestions from Spyderlovers, but am unable to keep the volume of the GPS loud. Here is what I do:
1. Go to audio screen and find am/fm and use set buttom to get to the aux screen
2. Push volume up so the volume is loud thru the speakers
3. Go back to regular screen and volume of radio is at the same volume of GPS
4. Turn down volume of radio and so does the GPS
Am not able to keep the volume of the GPS up while turning down the volume of the radio. What am I doing wrong? Thanks in advance.
I had the same issue. I found that my GPS had a separate volume control which adjusted the output volume to the radio. Once I cranked that up, all was good.
You do have the GPS plugged into the GPS audio input cable, right? The GPS volume does go up and down with the overall audio volume. You need to adjust the volume coming from the GPS to the level you want when the radio volume is where you want. They can be different, but both will go up and down with the vol buttons. If you're actually not listening to an MP3 player or iPod, after you have the GPS volume set where you want it you can mute the radio audio (hold vol down button in for a couple of seconds) and the GPS audio will continue to play.
