has any one done the cat bypass that can report on the benefits of doing this ,my main reason would be to allieviate some of the heat generated to passenger and side panels. any increase in performance or sound quality would be a bonus . 2012 rt-s se5
Removed mine and will never look back.
Eliminate most of the heat - http://www.spyderlovers.com/forums/...sults-of-Heat-Elimination-Mods&highlight=heat
I did it also and am happy with it. Only tests about 2 decibels higher BUT sounds better. Cooler, runs better and improved mileage. I think the big issue with a lot of folks is price. If you haven't gotten up close and personal with your Cat, you'll think, like I did, that all I need to do is get up under there with some pipes, measure and weld these up on my own. Reality is that once you get into the swap you recognize how incredibly tight the clearances are under there and how several things (hangers, bolts, pipe diameters, springs, VERY exact location of 2 inlets and one outlet) have to line up precisely. Frame clearances, etc are also extremely tight. They obviously had a LOT of work in getting these pipes where they just bolt up. IMO, they are cheaper than a simple muffler swap and give better results across the board.
Did you guys have to add a fuel management box and do you have any decel popping?
No, didn't have to add anything. Onboard ECM has enough range to compensate.
OK just broke down and placed my order for the cat bypass, one question I forgot to ask, can this be installed myself with car ramps and would I have any problems getting the springs off I know on some of my snowmobiles its very hard &tricky.
Not that i would do thisI can tell u from hearing how hard this is to do that its worth a pretty penny to keep from actually having to do this... And i can tell u there is very little sound difference. It is just a bit deeper.
Sent from my Galaxy S3. I may have made a spelling error or may have some grammer issues. My fingers are way to big to type on this tiny screen!
Rabtech,
Did you fabricate a bypass pipe? Any pics?
Just imagine that picture without the red thing in the center and then a stainless cover welded back over it.
How the heck would one get the RED THING out? Looks about impossible.
Get a Bigger Hammer !! :trike: :shemademe_smilie: roflmao
