cat problem
copilot
I'm trying to install a my cat delete exhaust but having a small problem getting the two nut and bolts to break loose where it bolts the muffler and exhaust pipe together. I'm afraid that I might apply too much pressure and twist the bolt off.
Any ideas would be appreciated.
2013 rtl
Run it for a while and get the exhaust
2013 rtl
hot, then remove the bolts, this seems to work well.
I don't think being rusty is the problem. The threads have yellow stuff on the threads that I assume so the nut will not back off.
2013 rtl
I had to use Liquid wrench and hacksaw. Then went to true value and bought new socket type bolts. NO more issues.
I have this issue a lot building firearms, the locktite is tough as nails and you certainly can cause damage, which is why I have a heat gun, game changer.
Another Day To Be My Kid's Dad [emoji379]
