Cat delete seals?
qasamm
I installed my catalytic converter delete and was wondering if there is suppose to be any type of seal or gasket used between pipes? Not that I think there is an issue but it looks like there was something in the original setup.
Sam Mancuso
2015 F3-S and 2009 RS
What is the purpose of removing the cat convertor?? Besides weight reduction, is there an increase in performance, fuel economy and such?
Sent from my SM-N900W8 using Tapatalk
Reduced radiant heat and it SOUNDs so much better. Yes an increase in performance as well.
Rumour has it that the primary muffler as BRP call it is not a CAT converter at all.
I have the Lamonster pipe and have yet to fit it, as I'm quite worried that it would
be too loud and my garage is directly beneath someone else's apartment. It may not go
down too well with them if I return from a trip (Daily) in the small hours and make a lot
of noise!:yikes: We do have strict noise legislation in the UK in respect of vehicles.
Install it, you will like it. It just is noticeable at idle if you heard another spyder to compare.
Sam Mancuso
Now you just need to add the Cadillac Converter.
attachment.php
