Bob Denman
So I'm guessing that there would be a need to address the direction of the airflow, as much as the amount of airflow... :banghead:
First, understand that the cat does not reduce greenhouse gases. It swaps one gas for another. (Reduces CO and increases CO2). And while it may help with smog a bit, it increases CO2.
Second, greenhouse gases and the whole global warming discussing is FAR too political and not allowed for discussion here on Spyderlovers. Suffice it to say there are many that disagree with your sentiments but lets not discuss here.
Back to Spyder discussions.....
Aren't catalytic converters used to limit the amount of greenhouse gases that go into the environment?
I know people are using the cat bypass to limit the localized heat when they ride, but, in the long term, the more greenhouse gases
that are put into the environment, make the environment hotter.
People complain about the temperature of the environment when they ride, but then remove the cat and potentially make things worse in the long term.
All the same; every little bit has to help... right? :dontknow:
Just curious to know, Jack, how that conversation went.Talked to BRP today about putting the correct engine in the new frame or making up the difference for the trade. the 2013 is the new frame and was designed to use the 1330 engine.
Removing the CAT is not the ultimate fix for heat dissipation. Don't expect too much. Probably only helped 10-20%. This is highly overrated. This will not solve your heat problem nor get rid of the noxious gas fumes. Had mine installed by PitBull at the owners event in Durango. I was disappointed. It did very little.The bypass is a well made piece of work but did very little for fumes and heat.I tried to trade for a 2014 last week in Las Vegas, Phoenix and Tucson (warm climates) best I could do was $12,000 for a 2013 RT-S with 5000 miles. No one down here wants them. Probably OK in the Northern Climes. Talked to BRP today about putting the correct engine in the new frame or making up the difference for the trade. the 2013 is the new frame and was designed to use the 1330 engine. Exhaust on the 998 is not compatable with the 2013-2015 frame. That is the reason for the heat problem on the 2013.
You do realize that the exhaust routing on the 2010 thru 2012 RTs is identical to the 2013 right? Its the revised component locations that result in much lower air flow under the tupperware that is the heart of the problem. The 2014 resolved it by moving the exhaust outside of the tupperware, not possible on a v-twin.
Let us know if BRP actually lends a hand to assist in any way.
