CARDO SCALA G9
SPYD3R
is there anyone out there that uses the CARDO SCALA G9 Head-Set unit.....?
if so.... do you have a cure for LOW VOLUME....? mine is OK @ FULL volume until i get to about 30 mph... after which the wind noise absolutely drowns out either the music or conversations that are going on...
i've seen videos of replacing the speakers with larger ones, but i hate to do that... any help would be greatly appreciated...
PS; Scala reps DO NOT answer my emails when requesting an answer....
thx in advance...
Dan P
SPYD3R
Try this
You used to be able to go online and update your units. I have the G9's but don't have a volume issue and do have noisey helmets. Use mostly Mp3 player and the intercom. Phone also works great. I have not upgraded but should do it online....:thumbup: is your source volume up...? if my Mp3 volume is down the scala is not loud....
thx in advance...
Dan P
SPYD3R
Make sure your speaker placement is correct. it they are not right at your ears it is hard to hear.
They have a jack on the bottom for ear buds. Using those instead of the speakers will give you more volume than you need.
THX
THX all....
i've gone into the software and updated many times... no luck...
i've made certain my speakers are exactly where they should be... no luck...
where is the 'jack' for the ear buds...? i don't see one...
Dan P
SPYD3R
