Capital letters don't carry over in quotes
Test for Quote
Lets see what happens. Hoping for the best.
The Days go on.
Now to see what we have here. :yes:.......:yes:.......:ohyea: I guess I am goooooooooddddddd to gooooooooooo.:thumbup: So anyone can do this..........:shemademe_smilie:
Thank You for the heads up.
Not sure what happened in the last post.
(the quote & the text line that's shown immediately above your last post as quoted ;) )
You (or the software) put in TWO [.QUOTE] 'initiators', but as IMS mentioned, somehow you've ended up with only ONE [./QUOTE] 'terminator' on the end - so the software ignored the first initiator cos there's no terminator; but the second initiator was followed by text & then a terminator, and cos it had a 'start' and a 'finish' it worked the way it's meant to. :thumbup:
If you'd had the terminator for the first one tagged on the end like this:
[.QUOTE=Little Blue;1566242][.QUOTE=IdahoMtnSpyder;1566233]
Thank You for the heads up.[/.QUOTE] [/.QUOTE]
it would've appeared like this:
BUT, if you open a quote & close it before starting the next, so that each is completed with its own initiator & terminator, it will appear like this:
(edited to add text to highlight the example)
and the Quote with text & Command Delimiters would look like this:
[.QUOTE=Little Blue;1566242] (edited to add text to highlight the example) [/.QUOTE] [.QUOTE=IdahoMtnSpyder;1566233]
See how each initiator is followed by a terminator?? Each "quote" needs to be contained within it's full & complete Command Delimiters, either sequentially to show one quote followed by the next; or 'nested' within a complete set to show one quote embedded inside the other. Make sense? :dontknow:
