Can't Unlock passenger seat - is there another way/work around?
mstella101
Is there another way to get the passenger seat unlatched and off? It isn't working with just turning key on the dash. I was wondering if there is a work around. Thanks.
Is there another way to get the passenger seat unlatched and off ? Isn't working with turning key from dash. I was wondering if there is a work around. Thanks.
To remove passengers seat you need to raise the drivers seat and reach under it to 2 tabs on the passenger seat that you have to push to remove it then just lift on passengers seat. PS the driver seat has to be up to get it out. Just turning the key does nothing to the passenger seat. :f_spider:
That might work on a RT, but on a F3 it's a turn of the key plus try pushing down right of center on the passenger seat as you turn and push the key.
Thanks, I had to take a couple panels off anyway, so I ended up lifting up the key cover and Voilà! Got it unlatched.
