bayoumanPIBE
Hey all...I'm looking at the various mods for making my brakes flash when deceleration happens...not only when the brake is pressed.
One of my options is the Volo mod. I emailed them to see if it would work with my stock two lights and the third center one I plan on installing from Custom Dynamics.
I told them I have a 2014 Can-Am Spyder ST-S SE5. They said "The volomod is the one that could make your brake or turn signals flash, for it to be able to do that your bike must NOT be on Canbus.".
WTH is Canbus...I know cannabis from my partying years, but...this is new. Only terminology confused me. I'm assuming it has to do with the electrical and bulbs...but, assumption has gotten me in trouble at times.
Can anyone give me the easy definition and let me know how I can find out if my bike is on it or if it needs to go to rehab...? :roflblack:
Also, if anyone has any suggestions on if the flashing during any type of deceleration is or is not better than Signal's flashing only if brake is depressed, let me know. Maybe if you have any suggestions.
Here's what I'm looking at other than a flashing mod with my personal notes...no need in responding.
[TABLE="width: 820"]
[TR]
[TD]Spyder Center Tail Light[/TD]
[TD]SPY-TAIL-LT[/TD]
[TD]$119.95 [/TD]
[TD]$119.95 [/TD]
[TD="colspan: 5"]Replaces spot between two tail lights as a center so it will be three rear lights between turn signal lights[/TD]
[/TR]
[TR]
[TD]Spy LED Converted Taillights[/TD]
[TD]SPY-TAIL-CON[/TD]
[TD]$224.00 [/TD]
[TD]$224.00 [/TD]
[TD="colspan: 5"]Will triple play make all rear lights flash?[/TD]
[/TR]
[TR]
[TD]SMART Spyder Triple Play[/TD]
[TD]SPY-SMART-TPU[/TD]
[TD]$149.95 [/TD]
[TD]$149.95 [/TD]
[TD="colspan: 5"]The Triple Play will work only when brake is pressed.[/TD]
[/TR]
[TR]
[TD]Spyder LED Rear Turn Signals[/TD]
[TD]Spy-LED-Rear-Turn - (Amber SPY-LED-REAR-AMBER)[/TD]
[TD]$54.95 [/TD]
[TD]$0.00 [/TD]
[TD="colspan: 4"]Will this work with the triple play? No.[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Spyder Double Feature Lens[/TD]
[TD]SPY-TAIL-REF[/TD]
[TD]$19.95 [/TD]
[TD]$19.95 [/TD]
[TD="colspan: 5"]Replaces reflector right on top of rear tire making it a brake/run light??[/TD]
[/TR]
[TR]
[TD]Street Magic RS Red Dual Brightsides™ (Running/Turn)[/TD]
[TD]SPY-RSBRIGHTSIDE-R-D[/TD]
[TD="align: right"]$139.95 [/TD]
[TD="colspan: 4"]These go on either side of rear tire replacing reflectors.[/TD]
[TD][/TD]
[/TR]
[/TABLE]
I'm also looking at Signal Dynamics license plate with modulator and their BackOFF Brake Hold Mod
- Black Classic Dual LED License Plate Frame W/ Red LEDs & 'Euro Clear' Lens
I'm asking them if it will work with the following making it flash as well as the brakes?
- BackOFF™ Brake Hold Module
Or can I use this Black AYN MOTORCYCLE License Plate Frame & Smart Module Combo
And then get the fBackOFF™ Brake Hold Module or the other brake lights?
Hmmmm....lot's to think about...and this is the only ones I've researched so far...thoughts??
L8R... :f_spider:
[TR]
[TD]$119.95 [/TD]
[TD]$119.95 [/TD]
[/TR]
[TR]
[TD]$224.00 [/TD]
[TD]$224.00 [/TD]
[/TR]
[TR]
[TD]$149.95 [/TD]
[TD]$149.95 [/TD]
[/TR]
[TR]
[TD]$54.95 [/TD]
[TD]$0.00 [/TD]
[TD][/TD]
[/TR]
[TR]
[TD]$19.95 [/TD]
[TD]$19.95 [/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
L8R... :f_spider:
