jcthorne
Well-known member
Got the CanAm Bluetooth module (Sena SM10) and Sena SMH10R headsets for Christmas and finally got around to installing / pairing them. The Bluetooth module is installed in the frunk as per the instructions with the supplied harness. Installed the SNH10R headset in my Arai helmet. Went through the very frustrating pairing process. Only frustrating because the instructions on the headsets show about 200 different ways to pair to all kinds of devices and never once mention how to pair with Sena's own SM10 module. Through guess work and trial and error, found out it pairs as a 'Selective Media Device' No idea what that means as the instructions make no mention of what the different device types do or why one would use them. I did finally get sound from my bike stereo into my headset. Not great sound but sound. Found later you have to use the audio boost function on the module. No idea why when the module and harness were specifically built for each other, nor was there any instructions in the install that this was necessary.
Anyway, Got pretty good sound. Shut off the bike, shut off the helmet and a few minutes later the module on the bike goes dark. OK.
Now try turning on the helmet, turn on the bike and .... NOTHING. Also the SM10 module is still dark. Is it not supposed to power back up with the bike? Next, I touch the button on the module and it lights up. Was I supposed to turn it off and back on with the slide switch? At any rate it lights up but still no sound in the helmet. I go through the whole pairing process again and it does repair. Please do not tell me this is what you have to do each time you ride?
Can someone PLEASE tell me the short and sweet version of how this equipment is SUPPOSED to work? A simple step by step for the easy way each time I ride to get it up and running?
Why does this have to be so hard? A simple one page instruction sheet in the CanAm module box on how to actually use it ON THE CAN AM would have been appreciated.
Thanks for any help.
