Canadian trailer hitch
From the pics, it sure looks to be of the same type design as BRP has for the RT, but cannot tell from the description if it is built by BRP. If it is quality built, would appear to be a good hitch.
You could always contact the seller and see if this part has a BRP part number...
That's a great price if it does! :thumbup:
I have one!
Tricky Dick,
I bought one from them and it's a great hitch. fits my RS perfectly. Paid via Pay-Pal $249.00 with free shipping. Had no trouble installing it either. Note: You will need a converter for the Spyder wiring from 5 wires to standard 4 wire. Reason: the Spyder has separate turn signal lights. Go to this site for more info: http://www.motorcycle-rack.com/WiringConverters.html Look for the TLC-175 model. Hope this helps.
John
Differences: Bolted together, rather than welded. No teflon/plastic sliders, but they may not be needed. Trailer plug on the hitch, rather than on the bike (RT issue, may be a plus for the RS)
All-in-all, doesn't look as strong (NOT an over-engineered BRP part), but probably will work just fine. At half the (msrp) price, worth consideration - especially if you use one of the E-bay "Best" trailers, like Yazz is pulling to Alaska. JMHO
I don't believe BRP makes one with a 'quick' disconnect like this one has. That's a pretty neat setup compared to others I've seen.
Looks like a good setup for an RS.....
I was a metal fabrication eng. for 15 yrs. before I went to my current job and given the light amount of work it would have to do I would buy it if I needed one without a second thought. Just as an example even if they only used a 1/4" bolt in a grade 8 and the load on that bolt is in the shear plane and it is, it would take 4417 lbs. of force to shear it. All this is given you have the proper torque. You can tell by the pic they used larger bolts and you have four of them. Hope this helps.
It is not a BRP hitch as BRP does not make a trailer hitch for the RS . They are a private company located in Quebec Canada. The hitch looks like it goes on the same way as one of BRP hitches made for the RT. I would google them first to see if they have a web site with more info on them. I have seen different posts on :f_spider:lovers for aftermarket trailer hitches for RS :D
He has 100% feedback, and if you click on the # (15) behind his name, you can see where he has sold three, and all three buyers seem pleased with the quality and workmanship.
The RT hitch from BRP works fine on the RS--- pretty sure this one would work on either as well.
Anyone using one of these hitches being sold on ebay from a company in Canada? http://cgi.ebay.com/ebaymotors/Can-...077480QQ_trksidZp5197Q2em7QQitemZ330518357006
Can you see any reason why this is not a good idea for a hitch on an RS?:dontknow:
I looked at these also. The one thing that puzzled me was the "removal of the rear axle" in their instructions. It may just be a typo but that would significantly increase the installation effort since the BRP hitch has a long bolt that allows you to mount to the factory hollow axle. You might want to just clarify that point with the manufacturer. I think the quality looks great.
I believe the BRP hitch also has rubber bushings in the sides of the hitch whereas the other one looks bolted metal to metal.
Yes, the BRP hitch has rubber and urethane bushings where the bolts for the brackets pass through, in addition to the poly sheets that line the brackets to insulate it from the swingarm.
Thanks to all for your input. I think I will go ahead with it.
I would be interested if they made an RT hitch.
they do have a hitch for the RT.
http://cgi.ebay.com/ebaymotors/Can-...9300639QQptZMotorcyclesQ5fPartsQ5fAccessories
I don't know what the difference is or why it's $50 more.
Tricky Dick,
John
John, anything unusual about the install? I assume you remove the axle to bolt it on:dontknow:
I appreciate the info on the converter. Which one did you get?
Anyone know why this person is selling the same hitch for 2 different prices ? Also any idea if this will work for an 08 sm gs ? Thanks.
Isn't really that big of a deal to remove the rear axle. Jack the bike up from the center frame to remove tension on belt--- remove lower rear shock bolt so you can slide belt off-- then axle will slide out easily.
I bought one, and just finished the installation today. I will try to answer all your points here.
I was able to stand on the hitch and it held just fine. Metal seems to be about a half inch thick, if not more. I did not measure it. The brackets are the same size as the washers used for the axle, so they seem to be strong.
Tricky Dick,
John
Their web site is www.remorquetrekker.com. Look on the top right for the word "English" to change it from French. They do not show anything about the hitch, but some nice trailers. I paid $249.00 also.
The brackets are held on by the axle bolt, then four (two on each side) bolts hold on the hitch to those brackets.
When I bought mine for the RS, and asked for more installation questions/photos. They sent me the pics that are used for the RT. They both look the same, so I don't know what the difference is either.
I am very happy with mine, although I have not towed anything with it. It took more than the 2 to 6 days to ship as they list, but that might have been because of customs.
Yes, you remove the axle bolt to install the brackets. then there is four bolts that hold the hitch to the brackets. Installing the brackets took me about 45 minutes, but I worked real slow, as I did not want to mess up the belt tension.
Yes, metal to metal.
Yes, was really easy, unless you do something dumb like I did. Had to redo the tension on the belt, but that was my fault, and not because the installation intructions were incorrect.
