Can the mirror clips be repaired
Johnny_Swindle
Noticed that my right mirror was moving about toward the end of a long ride. When I stopped I noticed that the wire clips were not hold the mirror tight against the bike. The item is 60b in the image (sorry simply could not get it larger with distortion. Has anyone had any luck bending the wire so that the mirror will hold firm or should I just purchase new clips?
If you remove the clips, the metal "grippers" for the lack of a better term, slide out. You can then flatten them back to normal, so they will grip as intended again. Hope this helps.
Thank you.....just waiting for the outside temps to go down a little before I go out and start working on the bike. Boy is it hot out.
