SpyderRx
Popping at low RPM and on decel? A little background, left Saturday for a trip to the ozarks. Bike ran great up until yesterday afternoon when it started popping at low Rpm going through town. Runs great when it is opened up at high rpm. Started the 480 mile trek home today and made it within 30 miles of home and had to stop for my last fill up. Filled up and turned the bike back on and tried to start and it would not crank. Checked all relays and connections. Called a friend with jumper cables. Initially put the jumper cables on the jumper connections and still wouldn't do anything. Pulled the panel off to check the battery connections which were fine. Hooked the jumper cables directly to the battery and started right up. Made it home and it died in my driveway while in park. So could the low voltage have been causing the computer to not properly measure and adjust the air fuel ratio. Popped a lot more in the middle of the day when it was hot (90's). My bike is an 09 GS SE5. Y gaskets replaced in the last 2 years. Bajaron plus and plug wires installed last fall. All stock exhaust. Sad thing is the battery was replaced in December of 2012 so it is not that old. It is kept on a battery tender. Thanks for any insight.
