Can I use a splitter for Multi USB connections?
bigjoe
2021 Spyder RTL has one connection in the glove box for USB. Can I connect a 1 into 2 splitter
and run my GPS and cell phone to this connection at the same time?
Probably not. These splitters are used for power only. You could try a small unpowered USB hub. Beware, even if the cable does support a hub, the connection does not provide a lot of power.
I added a docking station to my 2024 Spyder RT Sea2Sky that gets power from the accessory power port on the right side of the bike next to the right front wheel. The same dock would work on your Spyder.
My latest 2018 came with the 2010-2019 version of that. I bought a cig lighter plug in volt meter/two USB ports device, and plugs for the unused currently USB ports on it. The included USB ports on the other side are power my phone and dash cam.
