can fuel injector cleaner be used
Sea Foam in the cars and pick up. Good stuff in that application.
I use Yamalube Fuel Med RX in each tank of fuel. Stops separation of the fuel and prevents corrosion.
If you ride a lot and go through fuel quickly it may not be needed, but as somewhat of weekend warriors, sometimes for different reasons the Spyder may not get run every weekend.
I have posted about the Fuel Med RX before, so a quick search should find more info.
Honestly, whether you run pump fuel or non ethanol, it is cheap insurance to add something. Cars are much less finicky than a motorcycle with FI.
