I take it you are ryding an 09 SE5?? (It always helps to either let potential readers know what year, model, and transmission you are talking about - either in the actual text or as a permanent fixture in your Sig Line - see mine below, the 2013 RT Ltd's were all all SE5's.
) :thumbup:
Anyhow, if you are ryding a Spyder that has a V-Twin motor & not the 1330 Triple, then it's normal and it actually
NEEDS to happen!! It's the noise of a stepper motor that's holding the throttle bodies closed so that the engine can't ignite any gas fumes after shut down and either run on, or at the further extreme end of the scale, burn your Spyder to a crisp! :shocked:
If you actually time the duration of the noise, it should really only run for about 30 mins or so; but I believe there is some variation to that depending upon the temperature - higher temps mean it stays on a bit longer. So if it's really hot where you are, or where you park & shut down your Spyder, then a bit longer might be acceptable - but if it's
really running that stepper motor for as much as
2 hours from the last time you turned the ignition off, then you probably need to get it checked! :lecturef_smilie:
Other than that, it's normal; learn to enjoy it as one of the 'undocumented features' of these hi-tech engineering marvels that we ryde!
hyea:
Over to you! :cheers:
