Within one week, I improved handling and mpg on my RT:
Bump-Skid (critter splitter) - In addition to protecting the front underside of the nose, the unit seals a big cavity from the front to the rear of the front, stopping just in front of the suspension, a space subject to air drag under the Spyder. Gone. Less 'sail' from the faring. It also amplifies some down pressure on the front of the Spyder when at highway speed ... stability. Better aerodynamics = better mpg.
BajaRon's Sway Bar. Installed along with Bump-Skid. Combine this with my front Elkas Shocks ... The Spyder is on rails.
BRP Can/Am Spyder Sport Touring Vented Windscreen - reduced windsreen profile by 2" vertically and 3" horizontally. Less wind resistance and less buffeting. Helps highway mpg
Regarding mpg, the Spyder is always (and affectionately) a gas junkie when moving around streets and neighborhoods. The combination of the bumpskid and sport touring vented windscreen have my highway mpg up to 34/35 mpg solidly, riding one-up at 199 pounds without cargo. Mpg on the Spyder is strongly affected by passenger weight, two-up/one-up, trailer/cargo weight and other variables. The aerodynamic, and modest fuel economy improvements offered by the Bump-Skid and windscreen modifications, in my opinion, are most optimal at highway speeds (50 mph and over). Otherwise, the greatest influence on Spyder mpg is rider/passenger weight and cargo.
What about aquaplaning?? I am afraid this big flat plastic piece will act as a surf board on any puddle!
I'd love to have a metal plate under the engine.
Short of this.... You should be fine. :thumbup:
Having towed more bikes than I can count, over more miles than I can count, I can only say one thing...Nothing was cheap at SpyderFest.But had to get the BumpSkid from Pops. I was a wus and trailered my bike up/back from TX.
I had it strapped down on the open trailer. On the way back, I noticed in the mirror that the front straps were 'slack'! I pulled over and sure enough, the rear strap had broken and the bike had moved forward, going into the front rail/wall. Needless to say, there's a small ding/notch in the BS now BUT no crack or damage to the front plastic or frunk!
Was obviously worth the $. Have been busy since being back so haven't ridden enough to warrant comment on performance of it, but it surely can't hurt!
J / Roof Man
Is it necessary to lift the front end to install the bumpskid?
How many of you actually have a bumpskid installed? If so, why did you do it? Is the bumpskid really effective?
IMHO,....... better to have it and not need it, than the other way around!:gaah:
I had one installed at spyder fest works great.
