finless
So cool.... First commute into work today since getting my Spyder.
I commute 32 miles from west Orange County to El Segundo (1/2 mile from LAX airport) up the 405 freeway.
Since we have a diamond lane on that freeway (lane is for use only if 2 or more are in a car or motorcycles), the spyder is allowed in the diamond lane, this was one reason I wanted a spyder!
It cut my commute from 1 hour + to 35 minutes! :yes:
However I have to say it was a little freaky at first. I probably should have practiced riding in the diamond lane this weekend rather than doing it first thing this AM. I just did not think to do that while riding around Sunday.
Anyway the diamond lane on the 405 is a "add-on" lane. That is they took an old freeway and used the left shoulder to make the diamond lane. Thus it is not the same road bedding. They simply paved the shoulder to make it a lane. Thus there is a "groove" running down the right 1/4 of the lane. In a car if your right side tires are running on that groove, it will mess with you a little. So most people either run with the right tires near the double yellow separator line, or better drivers hug the divider wall (it's a solid wall that separates north vs south bound traffic).
Now 2 wheelers like to split lanes and use the section between the groove and the next lane to the right (standard traffic left lane), thus running up the double yellow seperator line. They do not like it much when cars are hugging the double yellow separator line to avoid the groove, as they cant get by easily.
OK so this AM I get in the diamond lane and figure out how to ride in it and avoid the groove. At first being timid I rode the right front tire between the groove and the double yellow line. However as standard traffic started to slow and then stop, this made me nervous to be passing them at 65 hugging the yellow line. So I went over the groove and started hugging the wall. Well "stupid me" kicked in with the death grip and micro managing the steering again :banghead:
After a little time I realized I was doing that and relaxed again. Over more time I started being comfortable hugging the wall so that is where I stayed the rest of the way except in areas you cant. Under some over passes the wall sticks out farther and thus the lane moves a little causing you to have to ride the groove a bit.
THE GOOD NEWS! Unlike a car, the spyder had no issue with the right front tire in the groove! I guess on a car when both the front and rear right tires are in the groove, it tosses you left and right a little. It did not do that on the spyder surprisingly. So while I will still avoid the groove anyway, it is good to know you're not going to get that left and right tossing around
Anyway another little learning story. It's all about building skills and many times the only way to do that is to just get out there and do it!
Only thing that did TICK me off a little..... I was doing 65 and a lady in a minivan was riding my rear end! She wanted to do 80. I kicked it up to 70 and said.,.. sorry that all I am going to do! I do not need my first ticket in 20 years to be on my new Spyder. She just kept riding my rear end even when I tapped the breaks a couple times. Finally at a diamond lane opening she went around me. I gave her a dirty look but really felt like giving her the finger and shooting some spyder venom on her
Bob
Bob
